BT Infinity & FTTx Discussion
Infinity, not slow, but some pages not loading first time here today. A lot like my horrific experience with VM and their chronic over-subscription.
Same. Was just going to post that my speed is still as fast as it should be, but web browsing is slow... as if BT are having routing issues or something... google dns here
Can someone help me understand what the PCP to Postcode spreadsheet is telling me?
For my postcode, the figures are:
Percent Lines: 100%
Uplift: 59.55
Phase: 6b
Deployed: Yes
FTTC or FTTP: FTTC
Obviously it also tells me my exchange and cabinet numbers.
This information seems to tell me that 100% of lines will get FTTC, and its been deployed. If this is the case why does the checker tell me I cannot have it until 31st March 2012?
Percent Lines: 100%
Uplift: 59.55
Phase: 6b
Deployed: Yes
FTTC or FTTP: FTTC
Yeah, it says 100% of the lines will receive FTTC with an average speed increase of 59% (I think?). It has been deployed meaning the speed checker is lying again.
I order my FTTC when the checker said it wasn't available for another 2 months. I managed to do it manually over the phone with BT.
[TW]Fox;21011700 said:
So it's available to me right now if I can just get past the BT website?
How did you go about doing that?
It *may* be available to you now. The only real way of knowing is jumping an Openreach engineer working on your cab (or in the area) and asking what he knows.
I was told it was available and had been activated for several weeks already (yet the activation date was well away). I rung BT once and got nowhere with a lady not really understanding it herself, second time (literally redialed) with an asian gentleman telling me it was impossible to that it was already activated, finally redialled for a third time to speak to a very helpful Scottish man that checked the details out and took the order over the phone. Activation was set for 7 days time, and the rest is history.
If your exchange is on the PCP to Postcode spreadsheet is there any way to get an estimate if/when (even which year) it's likely to be rolled out?
My postcode says:
Exchange Only Flag,Percent Lines,Uplift,Phase,Deployed,FTTC or FTTP
0,100%,18.51,Cornwall - Tranche 2,Yes,FTTC
As you're in Cornwall have a look here
Percent Lines: 100%
Uplift: 59.55
Phase: 6b
Deployed: Yes
FTTC or FTTP: FTTC
It means:
- 100% of your postcode is served from the same cabinet (which will be FTTC enabled.)
- BT estimate the FTTC speed in your postcode will be roughly 60 times what you currently get with ADSL.
'Deployed' Key
“YES” = Part of scheduled deployment
“NO” = Removed or Deferred from Scheduled Deployment
“Blanks” = Not part of a phase / untargeted cabinet
i.e. its planned for deployment - not that its necessarily already been done.
Any date which lists the end of a quarter (like 31 March) is just an estimate and not accurate. In mid-March the date will automatically change to 31 June.
Only when the checkers report a different date will FTTC go live on your cabinet (this can be only 2-3 days ahead of your cabinet going live)
Deployed means that your exchanged is enabled, not that your particular cabinet is done. Phase is just when the exchange became enabled, uplift, is freaking enormous which probably means you have cack internet now I assume, which should put your cabinet to the top of the queue speed wise.
THe issue is once your exchange is deployed every single cabinet needs doing individually, which takes a decent amount of time. Though I'm under the impression that highest uplift places should get it sooner rather than later.
I'm in the same spot, exchange has been enabled for freaking ages now, loads of cabinets done in my area, plenty of the post codes around me all done, just the one right in the middle they've not done yet for whatever reason :(
Just searched my postcode and found that there are only 3 with them same bit as me?
WWPTON PLYMPTON PL74SG {WWPTON}{M_B} 1 62%
WWPTON PLYMPTON PL74SH {WWPTON}{M_B} 1 71%
WWPTON PLYMPTON PL74SF {WWPTON}{M_B} 1 73%
What does the {M_B} bit mean, there is M_A and M_C all the way up to M_F although mine has only 3 entrys, the rest are a lot more. Does this mean my cab is likely to be close? I saw two new FTTC cabs being installed about 200m away from me so not sure which one i will be connected to, any way to find out?
I think you are directly connected to your exchange, so no FTTC or FTTP for you at the moment :(
Hold on, just found this on the same document?!
WWPTON PLYMPTON PL74SG {WWPTON}{P8} 0 34% 6.89 6b Yes FTTC
WWPTON PLYMPTON PL74SG {WWPTON}{P22} 0 3% 6.45 6b Yes FTTC
Does the exchange '1' or '0' mean you are directly connected to the exchange or not?
Im almost certain {M_B} means those 62% of lines are served by a direct connection to the exchange, and as above 34% of lines for that postocde are directly connected to cab 8, and 3% to cab 22, which are getting FTTC. So you need to find out if you are connected to cab 8 or 22.
Have you put your telephone number on the BT adsl or infinity checker website? That is the best way to tell (if you have a BT line).
The '1' means you are directly connected to the exchange AFAIK
I am with virgin media for everything (phone line included)
I have put my telephone number in to the bt website and it says its not available.
Do this mean that if im directly connected to the exchange that I won't ever get FTTC?
Ah i see - i would advise you get yourself on the thinkbroadband forums and possibly ask the chaps at ADSL24 if they could tell you which cab you are connected to. Do you have a previous BT line installed at your address?
If you dont have a BT line then the checker is useless. Do any of your neighbours on your side of the street have a BT line? It might be worth asking them to check on the BT website, as you are both likely to be connected to the same exchange.
If you are directly connected then no - at this point BT are not planning FTTC/FTTP.
If you dont have a BT line installed anywhere - and you need one installed, maybe you could ask them to connect you to a cab which will be getting it? Its a long shot, but worth a try i guess!
Well, we had one years ago, but when we had our extension built the builders cut the cable off because it wasnt being used (they cut it just after it is attached to the house), so tecnically, we dont have a bt line anymore. Looking at when our line goes to, I can see that the neighbours to our right are connected to the same telephone pole as us, but they also have Virgin so thats no good.
Using the BT website, I put in load of different house numbers, IE, Mine is 82, I put in 70 and 100 etc and found that 100 had FTTC available, and me and 70 didnt :(
