Server needs to ban admins from using /time at all. Tonight we had pretty horrible bug with redstone torches not working on further investigation.
This is basically the bug we are getting.
When using a clock circuit on an RC2 test server, the circuit contained an inverter in which the torch failed to light after approximately 5 cycles after the /time set command was issued. Reproduced the bug multiple times by deleting the world and recreating the clock.
The circuit was tested at varying times between 10 minutes and 1 hour before the command was issued in each test, never failing until after the /time set command was issued.
How to reproduce:
1. Make a simple clock circuit containing an inverter(or even just a torch that turns on and off with each cycle)
2. Allow the circuit to run for a few minutes to verify the torch is stable.
3. Issue a Time Set command to the server.
4. Observe the torch failing to function within a few cycles of the command.
Replacing the torches causes them to burn out immediately in one cycle, but if the circuit is left in place for approximately 15 minutes the circuit will begin functioning again.
Done this myself on a test server multiple times with dif maps and reproduced the bug every time. Altho sadly i could not get the circuit to start again without server restarts. Pretty nasty bug tbh as lot people love working with redstone including myself on the server.
