- 23 Nov 2009
- North Leicestershire
Ocuk don't sell them do they?
Correct.
Always so quick to reply
Where is the best place to check out radiator comparisons
was looking at rx480's or the EK xtx (480)
You can put a 480 (4 x 120) rad in the roof, but you have to mod the case, see here
That build looks so damn sexy, changing my mind about the rad box now, is the sr1-480 thinner than the XSPC that he is using?
roughly the same
No turning back now mate ordered some fittings of the MM and a couple of other bits from various places. Also time to get a new dremel me thinks.
Time for a dremel spec me thread LOL
Dremel 300 is tone of the best![]()
yeah i looked it's gone EOL now though apparently, Are the fittings all the same across the dremel range
Pretty certain they are
Try ebay, BIN from largish companies offer good deals.
BandQ also sell them![]()
That's the one I got![]()
Are the discs robust enough to cut quite a bit of steel on the HAF-X
