Epic Watercooling Case!
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Stock due to land end of Feb!
BitFenix Shinobi XL Full Tower Gaming Case - Black @ £139.99 inc VAT
We've taken our battle-proven Shinobi design and expanded it, creating a roomy, feature-packed full tower enclosure that will not only turn heads, but take them clean off. The larger size enables you to outfit your Shinobi XL with the latest fear-inducing hardware, including XL-ATX motherboards and the longest graphics cards. Shinobi XL can accommodate up to two 360mm radiators, making it ideal for water cooling enthusiasts. Four SuperSpeed USB 3.0 ports and the all-new BitFenix SuperCharge™ port keep your peripherals and mobile devices ready for battle, while the BitFenix FlexCage™ hard disk rack adds to the Shinobi XL's nimbleness. With three included Spectre™ fans, tool-free drive locking, filtered intakes and signature BitFenix SofTouch™ Surface Treatment, Shinobi XL is the chassis you need when vengeance is not enough.
- Dimensions (HxWxD): 570 x 245 x 557mm (ATX Full Tower)
- Motherboard Sizes: Mini-ITX, mATX, ATX, XL-ATX
- 5.25” Drive Bays: x 5
- 3.5” Drive Bays: x 7
- 2.5” Drive Bays: x 8 (using 3.5" drive bays and 5.25" adapter)
- Cooling Front: 1 x 230mm (included), or 3 x 120mm (optional)
- Cooling Rear: 1 x 120mm (included), or 1 x 140mm (optional)
- Cooling Top: 2 x 230mm (x 1 included), or 3 x 120mm (optional)
- Cooling Bottom: 2 x 120mm (optional)
- PCI Slots: 9
- I/O: 1 x SuperChargeTM, 4 x USB 3.0, HD Audio
- Power Supply: PS2 ATX (bottom, multi direction)
- Extras: Superior watercooling support, FlexCage™, SofTouch™ Surface Treatment, filtered intakes, tool-free drive locking
- Maximum CPU Cooler Height: 193mm
- Maximum Expansion Card Length: 377mm (with HDD cage) / 492mm (with HDD cage removed)
- Maximum MB Tray Clearance (rear): 34.5mm
Only £139.99 inc VAT.
ORDER NOW
Odd, I wasn't expecting to see an empty case lol
I thought there'd be a load of watercooling tubes pre-installed in the case lol
Cable Management looks good though
It's been a while Waldo, as soon as I have the money you'll see me there :)
In fairness if I didn't have a 420mm rad I'd happily change my Fractal for this case tomorrow. As it is, I think I may keep an eye out for another 470 and block to SLI it up, and get two 360's to go in the Shinobi. The one thing I would change about the Shinobi from what I've seen of it is to give it all 140mm fan mounts rather than just one at the back. Any idea whether 140mm fans will fit in the top or front with a bit of drilling?
So, other than the fact it's cheaper, why is this better than a Silverstone TJ07? (I've learnt it's probably best to not get the cheapest thing that should work, if you need to pay that bit more and do it right)
