- 5 Nov 2011
haha!
thats what i thought when i saw the 7970 for $550, and then it turned out to be about the same in pounds![]()
What I don't understand is why dual-GPU graphics cards don't behave more like CPUs (Intel's TurboBoost), in that when operating a single-core they operate at higher speeds while maintaining the same TDP. So a game that supports Crossfire will have both GPUs at a lower speed, while a game that doesn't can simply use a higher clocked single-GPU. The heat-output would be the same, which is the primary issue with single-card designs. Overclocking could be provided in both the traditional way and as an increase in the TDP (i.e. the card would be considerably noisier).
It seems strange that in a game that doesn't support Crossfire a 7990 will perform below that of the 7970, despite costing considerably more. Perhaps, going further, if a game is very memory intensive they could share the memory with a single-GPU, effectively giving you a 6GB card (which may be of benefit when next-gen consoles arrive and memory usage will inevitably balloon).
Currently dual-GPU cards perform behind two single-GPU cards, meaning that the only advantage would be if a dual-GPU card is cheaper or if the system has a restricted number of PCIe slots.
Bargain!
849 U.S. dollars * 1.2(VAT) = 655.556271 British pounds
No way would I buy this for £800. At most I'd spend £675 or so. I'm sick of all the UK prices. I'd only buy any card if the US UK price about evens out.
No it is $849, a straight conversion+vat gives £655 so at launch expect £699 maximum
$530 = £341
£341 x 1.2 (tax) = 409.2
We saw launch cards at £430 so I have no idea what you are going on about.
If you look at the equation they had already added tax, so they merely added the mark-up value. It's $850, which equals £546 - add 20% and you have £655. If it comes out at more than £700 then it's profiteering.The UK? 20% VAT. So you can take the £655 then add 20% and what do you get? £785. That's how it works out, and why you pay what you do for what you buy.
by the time the 7990 is released the 7970 will be forgotten about due to the nvidia releases whiping the floor with them.
one 7990 will prob equal a single 780.
my prediction anyway![]()
You'll be better off with a pair of 7950s that will probably cost that, and then over clock them.
You're forgetting tax, man.
Snip
Lol
Lolol
What you drinking, i'll have some
Why you think NV are late to the 28nm party? Yep, that's right, cause Kepler is a non-runner against Tahiti. Don't expect high end Kepler (aka 7970 rival gpu) before Q3 due to this.
