Thanks for reporting back nuhi, looking forward to getting one myself and having a play so we can compare notes..
Yeah, I believe it was +0.040 and LLC on Medium. LLC is very aggressive, basically you can lower your default voltage, since the CPU is not overclocked without Turbo being engaged, then on load LLC kicks in and bumps up the volts. So I could see what the real volts are only half-way into stress testing.490W
Was that with using offset?
Fixed is more stable for extreme frequencies as it doesn't have sudden dips on idle as with offset.which is best for overclocking then offset or fixed?
i was hoping to get mine to 4.5 for day to day assuming temos are good, maybe higher if it runs cool, but i doubt it from what you are saying.
I see the X79 IOH is getting a stepping change from C-0 to C-1 as well hmmm interesting.
This is tech torture
Not so far..
They don't know when the next delivery is or if it will be the new C2 stepping, at least that is the situation at 9am this morning
Anyone here live in Germany???![]()
