Mouse recomendation
30 Nov 2011
hi guys, I recently broke my OCZ eliminator and have been hunting around for a new gaming mouse, seen a couple with a "sniper" button that slows DPI to a predetermined low setting when held, thing is I don't like the idea of having to hold 2 buttons plus click a 3rd all at the same time for sniping
I picked up an M60 as it said that it's fully programmable however you can't assign mouse functions to their macros so you can;t get it to right click AND dpi set on a single button
does anyone know a mouse where you can set the dpi and another key (could even be keyboard I guess to set keyboard zoom on at the same time) on a single button?
been looking at the logitech g9x, gigabyte m8000x or steelseries Xai but can't find definitive answers on whether any of these support low dpi + zoom on a single button
cheers, Andy
I don't think any mouse could do that. You could buy a mouse with a DPI button and just wire in so that when you hit the DPI button it also presses M2? Thats the only way I think but will certainly void your warranty.
I have certainly never come across one that allows you to map DPI change to another button to another macro to the DPI button. Not even the Sensei and you can change pretty much anything on that.
the m60 lets you swap all the buttons around, so right click can become dpi set, but only one mouse function per button
(or as many keyboard keys as you want in sequence by recording a macro)
the rat 7 doesn't let you program the dpi set button at all
the gigabyte lets you macro mouse clicks but I don't know if it supports setting dpi to x via macro, I think the intellimouse explorer lets you set to x via any mouse button but I don't know if you can set it to be both right click and set x at the same time
if anyone has any of these mice and can say yay or nay it would really help me :D
so, I've narrowed it down to either the Roccat Kone+ or the logitech G500
these both support "dpi set to x" on mouse button hold (roccat call it EasyAim)
what I'm not sure of is if either of these mice (or associated software) let you stack 2 commands on to a single button, even if you have to do it via a macro that would be fine
does anyone know if the roccat software lets you macro the EasyAim function? or assign both easyaim and another mouse function to a single button at the same time?
my main issue with the M60 is just that it's so damn uncomfortable for me to use, so either of these are bigger and more likely comfortable, so just having EasyAim or whatever will probably be enough, but if it can do both things on a single button then all the better
cant you bind a letter on your kb for the button you need pressed and have a macro no the mouse to change the dpi and and press the button on kb?
That is one solution, the Corsair M60 does not support this however.
This is what I am asking, does anyone have a logitech (either G9X or G500), or a Kone+ or anything, and can verify that it can do a dpi set AND a keypress at the same time
I don't really want to spend £200 on buying 4 mice to test them all and then send back the ones that don't do this, the one I have tested so far does not do this
Could you not find a mouse with side buttons quite close to each other (most mice?) and rebind them and press them at the same time with your thumb?
I would avoid the Kone+, they still seem to have issues with the scroll wheel, mine lasted a whole two months.
This. Got one myself and it has 2 buttons just below left click for DPI setting (raise and lower it to pre-determined min/max values in the mouse software).
Example:
My G9X is set to have 5 increments of DPI ranging from 400, 800, 1200, 2000, 3200 and 5700. You can change any of these values at will, plus lower the number of increments also if you want. I use 400 for sniping, 800 for running around, 1200 in ground vehicles, 2000 in aircraft and the highest settings for amazingly hard oh **** turns, all in BF3.
Due to the button placement and the software being really good, this is the first mouse I've owned where I can truly change the dpi on the fly to my presets, which are all set by me. You can also program the mouse to change the presets you want based on the application you load, which is an insanely powerful tool in my opinion.
