Opera 11.61 released
7 Mar 2005
LU7
http://www.opera.com/download/
Changes since Opera 11.60
User interface
Fixed
New web handlers tab in the Site Preferences dialog cut off, dialog not wide enough
Crash when clicking "Use master password to protect saved passwords" checkbox
Occasional crash when clicking a link or opening a new tab
Opera crashes when closing a tab that has the Star Menu opened
Can't close Star Menu after opening Folders
Opera crashes while closing feeds tab while dialog is open
Opera loses advanced download settings after restart
Opera Turbo Tooltip repeated multiple times
Wrong new reload icon
Zoom factor lost after selecting another message
Bookmark star icon is not refreshed when the page is removed from the bookmarks
Drop support for Fallback Background = 0 and Fallback Foreground = 0 in skins, fixes layout in mail window with some 3rd party skins
Ampersands on main menu in WinXP with Zune Theme
Titlebar remains when entering fullscreen mode (XP)
Display and scripting
Fixed
thepokerbay.org user profile crashes onload
Crash in Carakan on WebGL benchmark
Crash on applying 3025 background images
Out of range memory access when using subpixel rendering
Secure IFrame with URL to image lowers security level to "Unsecure" (breaks Paypal checkout)
Opera freezes when loading a big session with the Tab vault extension
NFL.com crashes with admuncher installed
Overwritten document.selectSingleNode not called if invoked by helper function
load events fire on LINK elements pointing to existing local resources (link rel="stylesheet" href="file://...")
Do not cache invalid UserJS source files ("blacklisting" user javascript files on parse error)
Cannot scroll down with mouse wheel over IFRAME with scrolling=no if smooth scrolling is enabled
stylesheet not applied due to malformed gzip content
Userjs confirmation on secure pages pops up on every load of the page
Incorrect value of elements in ArrayBufferView created with byteOffset to an ArrayBuffer
Captcha Images is not refreshing automatically after site refresh
Mail, news, chat
Fixed
Opera crashes on updating mail from version 9.27
Crashes if you unpin the last message in the "Pinned" view
After few seconds locked attachments disappear from a mail
Check/Send (Ctrl+K) does not activate all mail accounts
Sorting problem with ungrouped mail list
Mail unread count is wrong
Users not receiving new mails because of QRESYNC. Added a way to disable QRESYNC in incomingN.txt and automatically disable it if fails to sync with QRESYNC enabled
Network
Fixed
Crash in host resolver when closing browser after loading large number of tabs simultaneously
IPv6 IP literal URLs "Invalid"
Security
Fixed
Fixed an issue where manipulation of framed content can allow cross-site scripting, as reported by Michal Zalewski; see our advisory
Fixed an issue here script events could be used to reveal the presence of local files; see our advisory
For some reason, especially noticeable when viewing this forum, I have found then when going forward or back to any of the sub forums there is a white screen flash between each refresh of the screen.
None of the other browsers I use does this and yet with this 11.61 release it is both annoying and distracting.
Anyone else noticed it..?
mmm for me it is when I click both forwards and back :(
I find it quite annoying and I have noted it in the Opera forums. It also does it for me on other websites and is most noticeable when the background colour is anything other than white, thus contrasting with that white flash.
I tend to find certain issues with Opera which make it difficult for it to become my default browser.
hee hee - hope that I have not spoiled it for you :)
I have found the modaco forums, AV forums and the tabletrom forums also do the same. As I spend quite a bit of time in those reading back and fourth from thread to thread I find it quite straining on the eyes to see the white flashing each time I navigate from one to another.
I will try the latest 12 build to see if that does it.
Not sure if anyone has had the same problem, my favicons don't seem to work with opera. Any suggestions?
Edit: ..on snow leopard btw.
