not using ssl is pretty dumb tbh. Try the other servers, there's an eu one and a non geographic one. I was using 443 for a while, switched to 563, works pretty damned well.
you must have a config problem. The servers are fine. Maybe your astraweb payment hasn't went through ? What do the logs say? Could be your ISP though. Can you get through on 3G on your phone?
Sounds a bit suspicious really, maybe do a shoutout any see if anyone else on Sky getting the same? could they have targeted your IP if you havnt been using SSL?
No problems using the astraweb's eu ssl servers via sky from here. I never had much success using SSL with grabit (at least on older versions), and use stunnel instead.
I would say try using SABnzbd, however that doesn't explain why you cannot access their site. What happens when you try and ping their domain? Or do a trace route and see where its failing?
This is something deeper than ssl guys, although he should be using it. Not being able to get to the site is v worrying. However a traceroute is what we need
