- 22 Mar 2009
I can see it only ES on CPU-Z (engineering sample) he can go much higher cos there is no warranty for ES chip.
Slower than i5 2500K at 5GHz.
Can I ask, what changes did you need to make to get the RAM to 2133?
Is this spam that I have to report?![]()
2011 boards cost pretty much the same as 1155 boards
he did say mostly
The main advantage of X79 is being able to use two RAM blocks.
Anyone who disagrees that that is the best feature clearly knows nothing about PC's![]()
Hmm yeah, but I'm not quite sure of the advantages of this either with relatively well priced 8gb vengeance single sticks you could stick 32gb in z68.... And very very few people would ever need more than that.... Unless you want some kind of extreme RAM disk....
kd
Yes, but the people who buy high end setups will buy the rest of their parts high end, won't they
Eg, you buy a high end CPU, mobo and gfx cards, you also buy a high end case!
~Clee
I was talking about even higher end![]()
