Maybe the case side pannels are off so they can take a photo of the inside! dumb ass.
and the optical drive inside is so you can still load using cd i would have thought but keeps the outside looking clean.
Few more mods in the pipeline, iphone pictures so sorry about quality.
It's a Fractal Design Define XL![]()
Gave my eclipse 62 a bit of a cable tidy, also installed some bitfenix pcie cables. And found the windowed side panel, quite pleased with how it turned out, particularly as the case isnt that great for cable management.
Firstly, Nice job!
I can see two what appear to be cable tidy hopes behind the edge of the mobo, is there not space to have them come through? that way it would look even smarter imo![]()
Hi James, wat white tubing is that you are using or is it coloured dye? it looks fab! would look great in a new switch 810 case to![]()
Murderbox MKII, I want one!
So OcUK guys when will we be seeing this case/setup in the complete systems department or will this be too expensive.
It looks truely amazing wish i could have one.
Its an MDPC mod.
