In this review i talk about the new Bitfenix Spectre Pro Fans that were provided from Kul1 who is the Bitfenix Rep on this forum - so a BIG thank you to him
I will be comparing these fans to the "Phobya Nano-G 14 PWM Silent Edition" fans which i reviewed here - a BIG thank you to OcUK for these
Also, this is my first time using a light-tent, im still learning my way around a camera
Anyway, here are the Bitfenix fans
Their packaging is very appealing, it has a sort of Industrial/Gothic kinda look about it - very nice
Once inside the package, you get the fan, metal fan screws (black), silicone anti-vibration fan mounts, a fan->molex adapter AND an LED on/off lead
On an interesting note, that LED lead is basically a font-panel extension cable, so i was thinking of attaching it to my HDD access Front panel indicator and watch the fan blink when using the HDD
What is very clear is the amount of detail and thought that Bitfenix have put into making these fans, they have even branded the rim of the fan, you would only see this during installation and it really adds to the confidence in the product because they have obviously spent a great deal of time designing these
Even in something as insignificant as the cable, it is flat, black ribbon cable with a black connector - this is stacking up to be a really impressive fan!
On the back of the fans, you can see there are much more strengthening posts than on a regular fan (only 4)
Another interesting feature is that the frame (which looks fantastic BTW) has fan holes for both 120mm and 140mm mounts
And for the modders out there that like to change the colours of your LED's, this seems very simple as they are just slotted into the outside with easy access
Comparing this to the Phobya fan, one can see that the designs are very different
The Phobya fan is much more understated, with a smoked black design and nice curved blades, it does look very sophisticated. On the other hand, the Spectre Pro's are much more Industrial looking, with very strong, striking features. The Spectre Pro's have a presence that the Phobya fans lack.
The construction of the Spectre Pro's and the Phobya fans are second to none, i can bend and flex the frame and there is no creaking and little deflection - both have very decent build quality.
The Spectre Pro's also come with more kit than the Phobya and there are a few extra touches, like the black fan screws rather than the plain silver with the Phobya, that really stand out.
I have also been given the 200mm Spectre Pro fan. I had actually bought a new case and was going to replace the stock fans with the Spectre Pro's so i took a few pics when i was changing them out
This is the stock fan; a 200mm Corsair fan that is 20mm thick and claims to run at 1000RPM and move 39CFM
And this is the Spectre Pro i will be replacing it with, Bitfenix claim that it is 900RPM and it moves 150CFM!!!
Something that one may not be aware of is that the 200mm Spectre Pro is one of the largest fans to use such a good bearing (Fluid Dynamic Bearings (FDB)) and other 200mm fans use much lower qwuality bearings - Good one Bitfenix!
Interestingly, the Bitfenix has many fan mounting positions and can fit a variety of mounting holes
Also, look at how much bigger the bearing is in the middle of that fan! That shows how high the quality of these fans are!
The Bitfenix fan is 25mm thick as oppose to the 20mm of the stock Corsair fan which is why it can afford to have such sculpted fan blades and uprated bearings - and the CFM really slow the increase! 39CFM->148CFM!!!
Since moving from the Stock fans to the Bitfenix fans, max GPU temps have dropped from 85 to 78, which is reasonably good - that is a 7 degree drop for little change in noise - i am quite impressed with these
In conclusion, i am very very impressed by these Bitfenix fans. I would go as far as to say that i prefer the styling over the Phobya fans. One must remember, however, that these are made for different jobs. The Phobya is very much a powerful workhorse that is understated and meant for attaching to a radiator in a watercooling setup. The Bitfenix is much more exotic looking, with some very useful features. I would seriously recommend the Bitfenix Spectre Pro's to any consumer that wants a really good fan and a really good looking fan too!
Just by chance, i also recently bought some Bitfenix Alchemy Extension Cables and i would like to add: If Bitfenix continue to provide such quality items - they will have a devotee in me
