Audio - 3GA to MP3 FREE file converter
2 Oct 2004
N.W London
Hi Peeps,
I have a few 3ga files I need to convert to MP3's
Please kindly recommend the best converter (FREEWARE) or if I need to pay then so be it...Hopefully it can be quick and efficient
Thanks
plays in vlc but not in winamp when i change the file extension....
also loses sound quality when doing it this way
any further software recommendations would be appreciated
thank you
Hi Peeps,
Thanks
If your media player doesn't contain direct support for 3GA audio files, but supports 3GP multimedia files, rename .3ga to .3gp or .mp3, then you can play the renamed 3GA files in most situations.
If your media player does not natively support 3GP and 3GA, a recommended solution is to convert 3GA to other popular format like MP3, WMA, WAV, M4A and etc. I recommend you a tool which is professional.
Hope it can help you!
