So, what if the surgeon in question continues to repeat the same mistake? Should they not be pulled up on poor practice? Personally I'd be a bit miffed if I had surgery and it was performed poorly because people previously were told to MTFU. It's better that the first person makes a formal complaint, sues or whatever, so the practice is improved.
OP - none of your complaints have much basis though without knowing what the norm is, you need to consult someone and find out what is normal for the procedure you've had. It's a fairly major operation so you will be affected in some ways. I would speculate you should be able to live fairly normally a year or so later, but as none of us are surgeons it's all conjecture.
It sounds like you maybe were not made aware of the procedure and possible after effects, in which case you should have been and I'd imagine if that's the case other patients are not being consulted properly. Not something to sue someone for, but the NHS/CQC should be made aware of your complaints as a minimum.
