[TW]Fox;21213852 said:Why do you all have condensation inside? Of an icy morning I remove the ice from the outside, get in and drive off straight away. The windows don't need demisting?
Same here.
I'd infact have thought that just jumping in a stone cold car and driving it instantly could cause more damage due to lack of oil circulation and oil being up to temperature where its protective properties are into full affect. OK a car warms faster under-load, but I can't see how a car will come to harm if it idles for 1-2 minutes to get a little temperature/lubrication before driving off.
[TW]Fox;21213749 said:This is why decent diesels have an auxiliary heater.
Leaving a car to idle to warm up is no issue, but it certainly doesn't take 1-2 mins for a modern multigrade oil to fully protect an engine, more like 15-20 seconds to wash any acidic deposits away, and circulate to all the bearings.
Sure you don't wanna thrash it til it's warm so all the tolerances are in the zone, but that is metal expansion not a lacking on the part of the oilthe crank. big ends, camshafts etc will all be floating in oil a few moments after starting, if not there is problems with your oil pump or the oil in the car.
My car gets a 30 second or so idle in the garage so all the parts are fully lubed then driven off boost/low rpm until the engine is upto normal temperature.
I don't have any condensation inside Fox, but if I get in and hang around too long, my breath can mist the windscreen, I hazard a guess most have condensation/misting due to sitting inside a cold car shivering while they wait for their heaters to defrost the front screen![]()
Not very good for the engine though.
Idling is't great for very prolonged periods and it's not ideal when the engine is cold either, as the fluids take much longer to warm up compared to just driving it, but it's nowhere near as bad as some people seem to suggest it is. They are just being overly cautious really.
If I were you I'd just nip out 5 minutes before everyone's fully ready to leave and turn it on, crank the heating up etc; any ice will be gone and it'll be nice and toasty by the time you get in it.
Cars should be warm before driven, hence why you can buy delayed engine switches which allow your engine to continue running and allow it to cool better than just switching it off after doing a drive. Ie. you turn your ignition off, and lock your car, the engine runs at idle for a few mins before turning off, allowing a slower decline in temps etc.
Surely turning your engine on is the same, but in reverse, you want the engine to warm at a slower steady pace to reduce risk of damage.
Life's too short to worry about damaging an engine to idle for five mins to get it warm.
Cool, where is this component.
Most anti-wear additives only start to lay down sacrificial Zinc Phosphate at 75-80C.
Cam loadings are highest at idle too, so you have the combination of highest loads and lowest protection on a car idling from startup. Add to this the cold air increasing wall wetting/needing a richer mixture and you risk bore polish and increase fuel dilution.
Obviously points taken above that you can't drive straight away buy you don't need 10mins to warm a car, even my leaky convertible is ready to go by the time ive scraped ice off.
Hardware and roller followers have mitigated a lot of the 'real world issues' but in reality idling a car from cold is not ideal and also a massive waste of fuel.
What a strange thread
I start my dag dag up in the morning, heater to full, fan set to recirc and it's usually warm in there and windows clear within five mins!
been a few cars stolen doing this (i leave my car sometimes on a morning) but i wouldnt reccomend it to anyone
