You may use a signature (commonly used in email messages) in your posts. You can specify in your profile a signature to use at the bottom of your posts. When you post, there is an option to use your signature. A signature may contain one or more images but they must fit within a box with maximum dimensions of 400 x 75 pixels (width x height) and with a maximum (combined) file size of 20k. Images containing mostly very large words or animated .gifs will not be permitted. You may also add 1 consecutive lines of normal or smaller text directly above or underneath the image with no spaces inbetween image and text. If no images are used then up to 4 consecutive lines of normal or smaller text is permitted. Do not pad out your text lines with blanks lines. A line of text is defined as having a maximum length of 400 pixels. If you want to turn the signature off in the future, you can come back and edit your post. If you have specified a signature in your profile, the box will be automatically ticked for you.
Anyone managed to exchange a C1 for C2 with Intel yet???
What contact method did you use to get them to agree to this? I would quite like to get a replacement if at all possible.Just spoke to Intel, they are going to swap my CPU for a C2.
I just called the number that was listed on the website, had an email from them confirming replacement.![]()
Which number did you call mate. I have tried calling them twice and have got nothing. Evan though both times they where meant to e-mail with regard to a replacement. I maybe am not speaking to the correct dept. I have a C2 3930K in hand now gonna see how this one goes. My 3690X is a good one which I may not now swop. I want the correct details though in case I change my mind.
