- 11 Oct 2005
- Derbyshire
Just check it with moving rudder on transmitter, fully left then right, if it does just reduce travel a little bit with your settings on Tx, there are other ways of reducing travel, ie changing holes that the clevises go on on be it rudder, aileron or at the servo end. You won't need a great deal of travel on any control surfaces on that model anyhow.
You will be surprised at how little travel/ movement you need to alter flight
), so I could always beef the rudder up with another long spar thingy.
