Did man really land on the moon?
(The answer is no by the way)
No, the complete opposite.
Rpm limited makes sod all difference.
THE FORCES ARE NOT DIRECTLY LINKED.
Just like properly on a plane and a moving conveyor belt.
No direct link, so no cancelation of forces.
Very much disagreeing with you. Your logic fails as does you comprehension of physics.
How the hell in your world does a spinning helicopter body. Stop the pistons. It doesn't at all. The only difference is the force on the crankshaft bearings.
[FnG]magnolia;21281654 said:This is a fact rather than a myth but if I have one sandwich and then I cut it in half, I now have two sandwiches. Where did the other one come from?
No no and no.You agree that if the turntable rotates when the blades are stationary relative to the helicopter, the blades will be rotating relative to the ground, i.e. they are attached to a drive-shaft or something similar within the helicopter which keeps them in a fixed position regardless of bearings. If this was not true, the blades would remain stationary as the turntable and body of the helicopter rotate.
So when the helicopter starts turning the blades, the blades are still experiencing the rotational motion exerted by the turntable, and in the highly hypothetical situation where the helicopter wouldn't be destroyed by the ridiculous RPM it would need to spin at, these would cancel each other out. It isn't the same as the aeroplane experiment as they are fixed to a driveshaft and not allowed to "freewheel" as the wheels of the aeroplane would.
[FnG]magnolia;21281697 said:Also, plane on a conveyor belt. The plane does take off.
Why did their arch enemies Russia admit to it then?
Go on - mythbuster that one.
What did the 1000s and 1000s of Ham Radio enthusiasts follow to the Moon?
