The point is you sweep once and then the damage can be permanent, some drivers will install and some wont.
I tested by installing about 6 sets of drivers, then i sweep then only 2 sets would install and the only way to fix that was system restore.
Then i did a fresh OS install and did it all again to make sure the first test was not a fluke and the same results happened.
Working fine for me, however what's this installing in command line when first booting after install?
http://www.rage3d.com/board/showpost.php?p=1336844482&postcount=12Roadhog said:So far these drivers are awesome in BF3. Runs much more smooth.
Here is a little benchmark. Going hunting, 2560x1440, Ultra, 4X AA. The min FPS increase is very nice.
11.12 RC11:
Min: 90
Max: 158
Avg: 129
12.2 Pre:
Min: 102
Max: 156
Avg: 130
Xeon W3520 @ 4Ghz ~ Asus P6T7 ~ 3x 7970 ~ 12GB DDR3 ~ Dell U2711
The Mac said:This CAT is missing the SDK, this causes all kinds of weird behavior if you try to cleansweep/atiman to remove prior CATs.
he simplest solution is to install 12.1 for none 7xxx users or before, then install this RC right over the top allowing CAT Manager to handle uninstalling necessarily components.
This will fix the AB OC issues, as well as the GPU-Z cat reporting issue...
The only thing ive found wrong with this release is after a length of time, powerplay ignores any unlocked vcore increases, and reverts to the bios default causing GPU resets if youve upped vcore and not flashed it to the bios.
terrible on skyrim for me with crossfired 5850's. massive artifacting unless AA is turned off.
then i went to uninstall and roll back drivers, uninstalled, rebooted and i lost all USB ability. luckily i had a ps2 mouse to boot to safemode and get some old 11.10 drivers on.
first set of drivers ive ever had problems with from AMD.
getting ridiculous this, anything about 11.10 for me is useless in skyrim, awful performance or/and artifacting all over the place with the green flashing bg. sort it out AMD![]()
cold boot didnt. i had a ps2 mouse nearby tho.
i went for a complete uninstall as i had to get rid of all traces of the 12 series, forgetting my usb drivers are amd heh.
like i say 12 series have no end of problems in skyrim, which is a shame as its the first group of drivers ive ever had problems from amd. it looks to be in reference to the AA application but i'll wait for 12.3 and see.
for reference i got green flashes with 12.1 and 12.2 gave me flickering blocks all over the screen which could only be turned off by turning off AA. im not saying this will happen to everyone but its certainly happening for me. no overclocks.
