Time to upgrade my Northwood P4
The P4 HT's were great, still see a lot of them about. What HD do you have? It might make the system quite sluggish with the new chip in there :)
The HD is as old as the P4 but I am going SSD SATA III. It's a full system upgrade:
Thermaltake Xaser II 5000 -> Xigmatek Utgard (if they can find one...) & extra intake fan
Thermaltake 360W PSU -> Corsair TX650 v2
Asus P4V88+ -> GA ZXAP-D3
P4 3.06 HT -> i5 2500k
1GB unknown -> 8 GB Vengeance LP 1.35v
Seagate (not WD as prev thought) 80GB IDE -> OCZ Vertex 60GB SATA III & Seagate 2TB 64MB SATA III
GeForce FX5500 (270MHz & 256MB mem) -> HD3000 iGPU
Stock cooler -> Xigmatek Aegir
Looks like you've done your homework already :D
I'm beginning to think Xigmatek make the best coolers - forget the noctua hype. (Still have to test the budget Gaia but even unboxing it I was impressed at the 17quid price point)
http://www.xigmatek.com/product_list.php?categoryid=1&subcategoryid=1
The SD1284 Looks badass ! (that's an awful lot of heatpipe coverage :D)
EDIT: DAYYYYIIIIMMMmmmm The more I look at that, the more I want :o
Do not dismiss the noctua and silver arrow. They are the big daddies of air cooling. Of course you can use smaller coolers, but you will find that you will soon need a bigger cooler once you push your cpu past 4.6ghz/1.38v.
Buy cheap, buy twice = false economy.
Edit:
Also dont skimp on mobo and psu.
i would look at teh crucial M4 over the ocz pos drives - only ever had problems with vertex 3
I have both, 2 x M4's in RAID 0 and OCZ Agility 3, both are quick, very quick..
I dismissed Noctua and Silver Arrow as being too ostentatious. It doesn't matter how big the pencil is, it's how you write your name.
You won't be writing your name in anything but baby scribble unless you get a decent cooler.
If you want your name in massive 5Ghz flashing letters, then you NEED good cooling. I hate large coolers, they are ugly, but it is a bit like the old medicine saying - the worse it tastes and all that...
I have a Noctua DH14, hate it, my rig looks lovely until I put that in, but I cant argue with the temps..
I can vouch for the M4's. I have two, zero problems and very quick. Also been impressed with closed loop water cooling. Not as good as custom but still cool quiet and a lot more space in my case.
i have also used both the M4 and vertex 3 - the ocz was returned twice and finally gave up - just simply failed to work properly on a Z68 board(ended up with bsods) - latest firmware and bios , and ofc bios set up properly.
changed to an M4 and voila - fast as **** and stable
@ Harlequin
I suggest you do a little editing before the Mods see your post:
OcUK would like you and your whole family to learn and share via our forums. For this reason swearing and the posting of "adult" or offensive material is forbidden. Simply replacing some of the letters in a swearword with a * or any other character is not acceptable. If you must then please replace the whole word with ***** or other repeated character. We also expect members to behave respectfully and not launch personal or abusive attacks on other members. Those who post for the sole purpose of causing trouble are not welcome here and will be dealt with accordingly.
Self-employed and working from home. Two PCs would be an expensive luxury.
Of course, I know that all too well. You may as well hold onto this one as a backup machine, unless it makes enough money to contribute to the core i5 system.
I have a console for games (hence no discrete GPU).
Likewise on the integrated GPU, until it kept giving me rendering errors (ATI can't be bothered to solve a HD series compatibility problem in their driver). It would have struggled with Fallout New Vegas anyway though...
