- 15 Mar 2010
- Bucks
I think going second hand is a nice way of getting into macs providing your prepared to upgrade it a little (ram/ssd)
Running Lion? Yeah.
In general use on a current model 15" MBP I lasted about a month before putting 8GB of RAM in it. I got annoyed with the beachballs when it started paging to the (mechanical) HDD. Snow Leopard on my previous machine was typically using about 2.2GB for the same usage. I was getting better productivity from a 2008 MacBook than the new machine, so the £35 for the upgrade was a no-brainer.
Paging may well be less of an issue with an SSD installed, but non-upgradability of MBA RAM would put me right off. It's an excellent ultraportable, but it's no MBP.
The 13" MBP is a cracking little machine. I had the original C2D equivalent and it was excellent.
i think the MBP are due to a refresh soon, i guess it will come in line with the ivy bridges. so if you can, i will wait as that is what im doing atm too.
To the OP, as I'd say to anyone, go into your local shop and have a look.
While the MacBook Air has a higher resolution display, its colour gamut is far smaller. After having a look at both, I went with the Pro; I found the Air extremely difficult to look at, and when you take the full-screen mode into consideration, the difference is much smaller than you'd expect. I am currently deciding on getting an SSD for it, but that isn't a definite yet. Do take a look at both though.
As for memory and Lion, 4GB for heavy office use is sufficient. That is, numerous tabs open, Word or Pages, PDFs, Mail, and more. If you're getting lots of page outs (Activity Monitor), that's when you know you need more memory. Photoshop might require a bit more, but that isn't an expensive upgrade. Come to think of it, the Pro would be a better option because of the colour gamut for Photoshop...!
Finally, resale value of Macs are generally higher than that of a comparable Windows machine, however you do pay more initially...to be honest I doubt that there is really a huge difference.
For what reason would I need 8GB of RAM on a Mac? My MBP with 4GB didn't lag or was slow in anyway?
Any real world differences in 4GB and 8GB on a Mac?
When playing around with large photoshop files? When keeping a laptop for more than a couple of years? Just like any laptop.
Just because you don't doesn't mean everyone doesn't.
7 hours is a only when u use the laptop with really light loads.....
Like internet browsing and basic light use - which I will be doing.
Am I right in saying the Air only has thunderbolt or does it have a mini display port? I'd want to get a VGA or DVI adaptor and something so I can plug a network cable into.
I take it that it has USB and an SD card reader?
http://www.apple.com/thunderbolt/
And because Thunderbolt is based on DisplayPort technology, the video standard for high-resolution displays, any Mini DisplayPort display plugs right into the Thunderbolt port. To connect a DisplayPort, DVI, HDMI, or VGA display, just use an existing adapter.
Thunderport = Displayport.
13" had card reader, 11" does not.
Air currently has 2 USB ports, but they are not USB 3.0
With the superdrive you could just get any external drive for about £25, the cheaper drive will have faster write speeds.
Makes sense, so a mini display port to DVI adaptor will work in a MBA via the thunderbolt port?
Easy.
