If it's the noise I'm thinking of, it's common and I wouldn't worry.
Do you mean when moving or stationary? If stationary, when you reach full lock you often get a noise that could be described as grinding (but more like a whining really) from the power steering pump, which is normal in my experience.
If you mean when moving slowly, a noise on full lock can likely be a knackered CV joint on a FWD car, but then that's usually more of a clunking than grinding! Grinding noise could be as simple as tyres fouling on the wheel arch. Everything standard and undamaged?
My MK4 Fiesta did the same, it was a brief whining noise from the PAS pump at full lock. Check the fluid level anyway just in case.
.Well if it definately happens when stationary you can absolutely rule out CV joint or tyre rubbing. So it sounds just like the normal whine from the pump when on full lock. If levels are fine and no leaks or owt - should be fine. If it starts to sound really nasty, followed shortly by having no power steering, you might want to get it looked at.
I was always told it's bad for the power steering pump to be in full lock..
surely ford, or any other car manufacturer would have noticed this?I've noticed it on a few Fords I've driven, My 15 year old Honda doesn't ofc.
cv joint'Ello, it's a mk IV fiesta and when in full lock there is a weird noise, like a grinding cant figure out what it is, thought some of you would know or at least have a better guess than i do
cheers.
so how are you meant to drivesurely ford, or any other car manufacturer would have noticed this?
It makes the noise but the car needs to be in VTEC to compensate for the power draw so you can't hear the PAS pump![]()
It's ok I'm powerfully built and I drink Red Bull so I can overcome any short comings on my drive to my company (I'm a director you know).
It's not a great idea to hold the wheel hard against the lock stop. The noise you hear is the pressure relief valve opening because you are making the PAS pump work into a "dead end", i.e. no fluid can flow so pressure increases dramatically. This is especially bad if the fluid is cold, and therefore more viscous.
There was an older car that had the PAS pump driven by the timing belt, and as the cars aged there were quite a few timing belt failures caused by driver holding the steering hard against the lock stop first thing in the morning. Can't remember what the make & model was now, perhaps someone on here will know? Most cars have a separate auxiliary belt for hydraulic power steering, so this is less of a problem (unless that belt snaps and gets pulled into the timing belt - not uncommon on some cars).
Oh, BTW it's 'have', not 'of'.
He answered too.
Why did you write of instead of have? Do you know it should be have? If so, why wouldn't you right it?If not, now you no.
