- 12 Feb 2009
- London
Well im getting 50fps average with a 6850 1920/1200 very high settings. What does framerate smoothing do?
Myself.
Also inb4ban.
You're not very good at ski'ing and you're using 2 of the most overpowered guns in the game. I really don't have much love for snipers in this game tbh... especially 'sniper montages'. You sit around on a hill and snipe FC's. If anyone gets close to you, you whip one of the best close-range guns in the game. Well done.
Bro...you sound mad
Brings back good memories of tribes flame wars.
So are people using the framerate smoothing option or not?
Does anyone actually use more than two armours? I'm pretty happy with playing one position now and improving. I did unlock most armours before the last big patch that reset everything but now I honestly see no point.
Anyone know if ascend has the ability to be modded?
Bro...you sound mad
Not at all... someone posts a video for comment, I make my comment.
Although, "bro", you sound like a prime example of the current retardification of PC gaming that is taking place thanks to that Asperger's Anonymous community, Reddit. Congratulations to you and the following posters for deflecting a discussion on the Snipers OP unlocks to some tired, puerile meme recycling. roflmaolololwtf
The phase rifle isn't overpowered, its an alternative rifle that takes large amounts of energy to fire, it pretty much grounds you limiting your escape. The falcon however is still quite op in the right hands.
Just got my beta key, looking forward to trying this.
I like these sorts of games, just they are few and far between these days.
Pretty much.
Phase rifle is actually considered worse than the BXT1 and I think all of the comp players use the BXT1 rather than the Phase Rifle. The Phase rifles only defining feature is the fact it can do 1 quick 510 damage shot, the BXT1 after the first shot has a higher DPS than the Phase Rifle.
Everyone knows the Falcon is pretty OP, the main thing about it is the fact it fires so freaking fast, the problem with Sentinel is that close quarters should be their weakness, but the Falcon takes this away. It still doesn't mean the class in general is easy or anything though, if you're dying to Sentinels too often, then you're not going fast enough, if you try and grab the flag at 150km/h then I'll kill you.
I think InKursion is suffering from a mild case of GoingTooSlow.
