Is there a way to bet rid of the flick up image before you enter the log in password? Find thid particularly annoying is using a keyboard and mouse.
Disconnect all other drives and do a clean install. Then connect back any other drives, including any other Windows installs. Then you can simply select your boot drive from BIOS (most usually have a quick select feature) without Windows 8 messing with your boot manager.Real stupid question time.
If I have a spare hd can I just install this to it and have the option to boot into it on my machine? Been really wanting to try this out.
Press Ctrl, then type in your password.Is there a way to bet rid of the flick up image before you enter the log in password? Find thid particularly annoying is using a keyboard and mouse.
I tried it, disliked it, took me 15 minutes to work out how to shut down with the mouse, also my mouse jitters if my hand is resting on it (R.A.T 5) works fine with 7 and could not fix it, tried drivers and turned off pointer precision once I found the option, it's just so cumbersome in operation and I will be avoiding it at release for sure.
Promoting Win8 to primaryFailed at 3.1 out of 3.3 gb. Is there a way I can resume this, guess I will look for a torrent![]()
does it come with a new build of Visual Studio?
