iam using ocuks asus eng gtx480 (£180) bought back in 2011 anyway this is the question would the two run sli side(asus) by side(evga) ?
Unless 7970's have increased to £900 I'd double check your maths![]()
just joking, im an nvidia fanboyIf you look around rather than refering to only Anandtech and only on the Chase Bench, you will see in actual environment the performance is higher on the GTX480 at 1920 res and below; most of of those BFBC2 results of Anandtech are on 2560 res with 4xAA...so the lack of VRAM cripple the GTX480; and the 6970 is faster than the GTX480 is faster at 1680 res because of no AA used.In the link I posted the HD 6970 beats the GTX 480 in more benchmarks than it loses.
It also beats the GTX 480 in 2 of the 3 BFBC2 benchmarks with 4xAA.
)Around 60% of the price of a 7970 for 77% of the performance, amazing value 480 here folks
Ninja maths editkind of
People say these are power hungry, what is the min PSU for a single card setup?
You have to bare in mind that comparing to overclocked SB i7, platform such as overclocked previous gen i7 has something like at least 50W higher power consumption.I would say a HX620. I am running 2 however on a 800W coolermaster so don't belive those out there that say you must have some 1200W monster.
The HD 7870?
28nm
DX 11.1
PCI-E 3.0
MLAA anti aliasing
2GB of Memory compared to 1.5GB
Obvious lower temps and better overclocking capability
Kepler cards will also have better features then the GTX 480.
Imho if somene is considering spending near £200 on a new GPU it's worth waiting to see how 78XX and the first Keplers perform....
GTX 480 really is showing it's age these days, Hot, power hungry and loud. HD 6950 2Gb or GTX 560ti/570 or 78XX/Kepler would be a better option imo...
Each to their own though...
You said the GTX480 is "3 generations old" in comparison to what, 6900 series cards?
Because that's what's out there at the moment and the 6970 certainly does not
Technology process means nothing, DirectX 11.1 means nothing, PCI-E 3.0, again, nothing, MLAA on AMD cards, FXAA on Nvidia cards (the latter is usually better which is why it's widely implemented post-processing feature in many new games), 2GB vRAM I've already mentioned - not an issue for anyone playing at a moderate resolution (1920x1080 or so), lower temps will be a problem for some but not for everyone, see my previous post - I wouldn't buy the GTX 480 with no intentions to watercool it and the last point, better overclockability, well, you have no idea if it does. GTX 480 overclocks better under water than HD6970 does so that point is also moot.
So tell me again, how is GTX480 behind in terms of technology?
