Yay congrats mate !
Glad to hear you had success , ive got 2 old broken cards that i might try it with, purely for fun !
Thanks
Yeh why not mate, If you look on allot of forums about this then youll find tonnes of people who its worked for, nothing to lose!
I used my top oven, Although the card doesnt emit any fumes or burn in any way (is only in there long enough and a low enough temps to just about melt the solder and heat up the card) just to be safe I dont want to die of some sort of poisoning lol
It will brick again. I had it 2 8800gtx's. Have done the oven trick. It did work - one last about 6 months, the other one about 4. So if I was you, I'll start saving for another GPU.
Lol ive got a 7970 arriving tomorrow, I was just using this for a few days between selling my 6970 and waiting for that to arrive (bought this for my lil bro's pc but havent got a PSU big enough yet)
Great card... is perfect now and even better than new after replacing thermal pads and paste, it isnt
that far behind my 6970, overlclocks to 825/4000 mhz (but I am taking it back to 775/3800 just to be safe, although aslong as its not over 100 degrees it really makes no difference now the solder is completely fused) all on stock volts.
An the temps are amazing... 38 at idle and just 62 on full load.... cant believe the temps this cards meant to be hot but at the clocks above thats how hot it gets. When the room warms up it goes up to a peak of 69 but stays under 70, most of the time its at 62 max, very surprised.
Seems solid now and good as new, played many hours and stressed the hell out of it, unless I make the card change temps quick (for example make it go hot and cool hot and cool too much and too fast, idle/load, this is what bricks them and causes hairline cracks in the solder) And dont overheat it like 90 degrees plus and stay under that I think it will be fine....
At the end of the day it cant just magically break, if the solder is fixed its fixed. You have to either overheat the GPU or overheat it and have it throttle so it changes temps too quick causing stress to break it, if you dont then it cant break, theres no moving parts is there, its just lots of metal connected together and if it isnt hot enough (or had any repeated sudden change in temps) to be altered or caused stress in any way then it cant move or be damaged.
