Lines on screen - Laptop.
15 Feb 2008
Have a Acer 5742 laptop which has being good but over the last 3-4 weeks i have being get lines down my screen along with a sort of fuzzy line around the screen at the top.
Also the laptop will randomly shut down with no warning and takes about 3 attempts to restart, i thought this was a heat issue and have given the laptop a blast of air but problem still occurs. Temperatures average around mid 40 degrees :eek:
Laptop is about 13 month old (typical now there is no warranty).
Any one have any advise, thanks.
Even if it was sold with a 12 month warranty you may still be able to enforce your rights under the Sales of Goods Act.
Have a Google and read up on expected durability of products. Your retailer will probably try to fob you off, so don’t give up at the first refusal.
I had a similar problem, sometimes it would start up, others it would have lines going across the screen, sometimes green, different direstions and everything, it was a faulty stick of RAM (I already knew this, I bought it broken) put a new one in and it works fine! Try a different stick of RAM, or try it in another laptop if you can, it fixed mine!
i would give this a go mate but i have not a clue where the receipt is ... i have every other important receipt except my laptop.
will give memtest a run as i don't have any spare laptop RAM to try. I think atm there is 2x2 2gb sticks so will test each stick.
my old acer used to do this once in a blue moon, I gently tapped the base of the screen and it solved the issue :)
lol! have being doing this to get rid of the lines but they seem to come back after 10 mins or so.
