I think that this is a better plan than trying to offer a full FTTP network. This allows the customer to decide which they want.
The On Demand FTTP service is or has being tested at a few locations. The great thing is about this is that BT are upgrading as fast as possible most areas to FTTC has they have kept saying. I know that lots of people keep checking to find out when there exchange and cab is going to be done, but with the amount of CAB's that need installing, which is not as simple as it sounds. This job alone can be a real pain in the rear. OK they don't need planning permission for the CABS BUT they do have to get the ground work plans approved by local planning and the permission to dig the road or pavement up to route new feed cables between existing Phone cabs and the NEW FTTC CABs as well as power into the FTTC cab, the gear wont work without power.
Its all the above with the local council that is the part thats taking the time to get in place. But then they have to organise crews to do the work, and install the cabs and then wire them up. I watched 2 guys wire a new cab up with the new connections from the POTS (Phone Box) to the new FTTC box they had 4 cables with 128 pairs of wires to connect. Now that's not a 5 min job. Then they have the Fibre guy's that have to connect the fibre cable to the termination block is the Cab. This is a delicate process that has to be done with some real delicate stuff and it has to be perfectly aligned otherwise it will not work.
So yes knowing what's involved to get these services its no wonder that there has been set backs. Our own exchange was enabled in September last year 5 months after it was supposed to be, and that meant our cab was not enabled until December 4 months after the original date. This was all because the trunk that was going to be used for the fibre had to be replace with new due to a collapse hence a 4 month delay while getting the needed permission to do the work.
