Wave goodbye to playing all your favourite Xbox 360 games.
See why it wont happen now?
Vonhelmet 'to eat hat' in 2013.
All my old cartridge consoles still work to this day. PS1 disks are all scratched up and useless, PS3 died after 4 years, but the 'ol 2600 and NES are still going strong.So effectively they're going back to cartridges.
This could be a good thing.
Everyone knows cartridges are awesome.![]()
If they are going to alienate all the blue ray users and dvd's they may as well fire up the old hd-dvd press again and make games just on that format. It would help protect against the pirates and give them a cheaper means than making games on the equivalent of cartridges again.
My thoughts exactly and also to add the pre-owned market would take a huge nosedive ie trading in old games.
Its the reason we moved from cartridges to optical media in the first place, its only acceptable in portable devices because having something mechanical eats battery and isnt really suitable for the portable environment.I was thinking this a few years ago but then you need to look at the cost if ms goes with blu-ray it would cost only about 40p to produce a game disc hddvd your looking at between £5-£10, this is why they wont go down the cartridge route it costs more to produce them then discs and there is a lot more disadvantages then advantages discs are very easy to produce.
Surely 50GB DL BD discs will be a lot cheaper.
I hope there is no disk drive.
Games on micro SD cards are the way to go.
Maybe invent a new type of cart like N64 had but smaller. Memory chips are cheap now so it wouldn't increase game price & would load instantly![]()
