Unigine Heaven DX11 3.0 released
The lighting looks incredible!
Getting an average of 30 fps with all settings maxed, at 1080p
Edit: it uses 1507mb of my ram. That's pretty much all of it :eek:
It wont run 1400p in full screen! There is`nt even an option for that resolution
Just select "custom" and put your own resolution in (2560x1440?).
Or presumably selecting "system" will do the same thing assuming you're running the monitor at the native resolution.
Edit:
Yep, "system" runs the benchmark at the resolution you have set at the desktop.
gpus at 830/1250
cpu at 4.6ghz
Your cpu is at 4.6 and i had other things running on the pc ece but our scores are near enough.
Might try a run with cards clocked and cpu @ 5.2 later.
