Alpha counter works wonders against and derp safe special like Galactic tornado or Patriot Circles.
Rufus shouldn't be using non-confirmed GT's anyway though, there's no need.
Alpha counters are amazing, saved me from being mauled by rolento so many times
Rufus GT is good for cornering people though, blocked or not, so I just throw it out..
Ggs vian your teams looking sweet
Raw launcher is completely invincible to low attacks I heard.
no problem mate, we had a good laugh after you left. i notice raw launch beats every crouching meaty, regardless they hit low or not. still trying to get the timing for alpha counter, its very hard. do you press the button after you blocked or as you block? neither way i couldnt get one to work consistently.
It's really easy, all you need is my godlike execution.wave dash online with kazuya is hard dont know how kenny did it so well the other day. and i cant hit my full steve bnb to save my life onlinesteve and kazuya's links are real easy though, i dont think i missed any of them.
Sticking with Ryu/Akuma at the moment (boring I know). Any decent combos when tagging?
I'm using cmp,cmk,tatsu (or Ryu's super when it's available) but that's pretty boring.
I'm doing ok about half the time. It's already been mentioned but I am struggling with incessant jumpers. Also Hugo (I think it is). He only has to hit me about 6 times on full health and I'm KO'd. He seems a little OP to me.
I'm using the same characters as you atm until I have a better understanding of the game, it is nothing to be apologetic about, characters are there to be used. You should have no problems with incessant jumpers, use cr.hp or mp.dp and they will soon stop jumping in.
XBL: mpower07
Add me for some games if you are on xbox, I might be doing some things you can take and vice versa.![]()
You are already friends with me (ShortWarning).
