Hi,
I am having a bit of trouble building a shed base. I decided on a 2" x 4" pressure treated frame, but I was going to sit this onto piers to lift it off the ground. Only trouble is that I have bought medium density concrete blocks, that I have now found out wont do as they crumble over time :/.
I bought ballast and cement to make concrete and was going to dig out 8 holes, 4 each side, then put the blocks onto the concrete pads. Then sit the timber frame on top of this.
Is there anything else I could do? I don't really want to spend any more money on this if possible. I'd also like to use the blocks up some how. Maybe smash them into hardcore?
The shed is fairly large at 10' x 8' and the site its going on is turf at the moment, with clay soil under.
TIA
TIA
		 . It was a lot smaller though at about 5' x 8'.
