was absolutely terrible but served me well
) that you are supposed to screw the mobo into. I decided to tidy the case up a bit and an hour or so later:
Does anyone know if there's anything else I could do to hide the wires a bit better? I struggled to get the back of the case on tbh, I don't think it's quite right.
extension things? you mean motherboard standoffs? surely you didn't just screw the motherboard to the case...... does it still work? if so, consider yourself very lucky tbh
the standoffs are usually a brass/copper color, and they should come with every case![]()
As for the cable routing, it looks ok tbh, you could get old of an old PSU cover to further hide the cables from the psu to where they go behind the case but it's not essential
Another Antec Mini P180 owner. ^^
Massive pics though.
Yeh man i've been keeping an eye on your build logs, have to say i'm a fan of your work!
