ongoing 7970 crossfire problems
You already have an i7 920 Do with 12gb of ram there is nothing worth upgrading to for games :confused:
If you really need an upgrade get a second had 6 core cpu for around £250 after you sell your 920
And that psu are using is awful its cutting out and restarting because its pull more load than the psu can handle and tripping much like a circuit breaker in a house to stop it form blowing up. :eek:
Also get a 'quality' 850w+ psu as you will want to overclock them beasts at some point so best to have the head room and buy the best you can afford as a good big psu will last through many builds.
also the person saying get more ram 12gb is fine on the X58 as it use's tri-channel ram ie
3x1,3x2,3x4 3gb,6gb 12gb
I'm pretty unhappy with the performance of my setup at the moment, would I be able to persuade you (by means of cash) to give my rig a once over, I've never really been -that- into hardware so I just buy decent stuff but likely set it up wrong.
what say ye?
