Why?
edit: Check out the performance of a single 470 vs a single 7970 (click me). As you can see there's a huge gulf in performance...
The 680 appears to be a fair chunk faster than the 7970 at the heaven benchmark, so it shouldn't come as a surprise that the 680 gets a higher score than SLI 470s.
So the GK104 is the tessellation MASTER??
With the launch on the 22nd I need to get my final rumours list updated.
The HKEPC results at 1920X1080 and using 8XAA have a very different spread though.
In the HKEPC preview there is around a 10% difference and the newer results indicate around a 30% difference.
This literally made me laugh out loud.![]()
You haven't seen my final list yet!!
... At a different resolution, using different AA settings.
It is to be expected that the gap will close somewhat as the resolution increases - due to higher memory bandwidth on the 7970.
It had better include that the 680 gives head, tidies and dusts your room and then makes you a nice cup of tea.
Either my 470's are broken or somthings fishy with the 680...
I feel sorry for the guys handling the RMA...
Your 470s are broken:
Now thats where I was expecting mine to be.
Maybe I had to restart my pc or somthing.
Anyway, just did a few benchmarks on Arkham City with different CPU clocks (3.8/4.0/4.4/4.8) and it doesn't seem to be "CPU heavy".
I wonder if someone in this thread who has a Core i7 2600K or 2700K could run the AC benchmark??
So,ATM a 1.3GHZ GTX680 will give you 112FPS with a 3.4GHZ Core i7 2600K and a 1.125GHZ HD7970 will give 98FPS with a 4.4GHZ Core i7 2600K.
I found another HD7970 3GB score from the same website with a 1.235GHZ overclock using the same settings(1920X1080,4XAA,very high settings):
http://www.overclockersclub.com/reviews/powercolor_lcs_hd7970/6.htm
The RAM was running at 1.76GHZ though and the HD7970 scored 111FPS.
The scores look similar but I am wondering how much the 1GHZ overclock is helping the overclocked HD7970 3GB at 1920X1080.
So,the 1.235GHZ HD7970 should be around the same as a 1.3GHZ GTX680 in the Batman:Arkham City benchmark.
But did he have phyx on the GTX680?
Although, then again it is the phyx MASTER so can probably run it without taking too much of a fps hit.
Isn't te CPU supposed to handle physx as default in Nvidia control panel?
IIRC Auto is the default.
But did he have phyx on the GTX680?![]()
