But Ferrari wouldn't slap a Ferrari badge on a Focus, tweak the ECU a bit, and charge a Ferrari price for it![]()
Aston Martin would !
http://www.astonmartin.com/cars/cygnet
I think the price range there was for flagship cards though. Not smaller brothers that could be flashed or unlocked.
9700PRO was the flagship
Just for info.
Launch Prices (AMD):
9800Pro = $399
1800XTX = $449
1900XTX = $649
2900XT = $399
3870 = $249
4870 = $299
5870 = $379
6970 = $369
7970 = $549
Launch Prices (nVidia):
FX5800U = $399
FX5900U = $399
8800GTX = $599
9800GTX = $329
GTX280 = $649
GTX285 = $399
GTX480 = $499
GTX580 = $499
Really? so what about the 9800pro?
Just seen an etailer in the US $578
Never used to be like this. I remember snagging a top o' the line Voodoo 2 for £89 at a computer show many moons ago. Those were the days.
Supposedly the difference between the GTX680 and HD7970 is similar to the difference between the GTX580 and the HD6970:
http://forum.beyond3d.com/showpost.php?p=1630025&postcount=3048
Here is a picture of the control pane where you can manually change the Turbo Boost percentage:
http://forum.beyond3d.com/showpost.php?p=1629879&postcount=3000
The TDP is meant to be between the HD6950 and HD6970. Power consumption and TDP of the GTX680 might end up being similar to an HD7950 3GB. Considering the HD7950 3GB has a more complex PCB and more VRAM,I wonder how close the TDP and power consumption of the GPUs(not the full cards) are though??
Only 200 FPS target? I have TF2 set to limit 241 FPS because they say (refresh rate*2)+1 = best for smooth gameplayHe is a picture of the control pane where you can manually change the Turbo Boost percentage:
they will have to drop prices on both existing Green & Red GPU's to avoid being left with a lot of unsold stock........Only 200 FPS target? I have TF2 set to limit 241 FPS because they say (refresh rate*2)+1 = best for smooth gameplay![]()
12MB Voodoo2's were $299 at launch.![]()
AMD will have to drop prices when the high end Nvidia GTX drops in a few months.
