GTX 580 "Phantom" 3072MB or 680 ?....hhhhhhmmmmmmm decisions decisions
do you need 3gb VRAM ?![]()
Wll I've seen BF3 maps (Caspian Border) peak at 2050mb vram usage so I'd say even a card with 2gb would be a bad choice - and it's only going to be more so with the games we'll be seeing this year.
Performance wise I would say definitely yes, but I would also consider toward the rest of your rig. If you are still stuck on Core2Quad or Phenom II X4/X6, you'd best upgrade to IvyBridge to compliment the GTX680 to make sure you will get the most of the card.I am currently gaming @ 1080p, is it worth getting a 680? I'm moving from a 460 Hawk Talon Attack.
I have upto £600 to spend on a Graphics Card/Sli. I just want to max everything out and not worry about upgrading.
I know I'm sounding like a stuck record but just because a card uses 2GB of vram doesn't necessarily mean a card with less vram would suffer a performance hit.
Looks like ocuk have just increased 7970 prices, wonder why?
400 pounds seem an expensive way to find out that the opposite is true in 6 months to a years time.
So without price gouge which in very unlikely, these should be no more than £389 inc vat.
