680 Limits PCI-Express to Gen 2.0 on X79/SNB-E Systems
30 Mar 2010
Under The Stairs!
'GeForce GTX 680 Release Driver Limits PCI-Express to Gen 2.0 on X79/SNB-E Systems.
Users of systems running Core i7 processors in the LGA2011 package and X79 chipset motherboards will find that their GeForce GTX 680 will not run at PCI-Express 3.0 x16 mode, using launch drivers. This is because NVIDIA decided against implementing Gen 3.0 support for the new GPU on X79/SNB-E systems, at the very last moment. Pre-launch drivers, including the driver that ships on discs with the graphics cards, and review drivers (which cannot be distributed), will let the GPU run at Gen 3.0 mode on some X79/SNB-E systems, however the post-launch stable drivers (such as GeForce 301.10 WHQL), won't.
The specifications page of GeForce GTX 680 on GeForce.com has been updated to mention this:
GeForce GTX 680 supports PCI Express 3.0. The Intel X79/SNB-E PCI Express 2.0 platform is only currently supported up to 5GT/s (PCIE 2.0) bus speeds even though some motherboard manufacturers have enabled higher 8GT/s speeds.
Sources in the PC motherboard industry we spoke with, confirmed this change. PCI-Express 3.0 x16, for now, might only run on upcoming "Ivy Bridge" Core systems, running on motherboards with PCI-Express 3.0 compliant components. NVIDIA could be working to fix the issue.'
http://www.techpowerup.com/162942/G...-Express-to-Gen-2.0-on-X79-SNB-E-Systems.html
Don't think it much of an issue myself but just thought I would give a heads up.
Apologies if it's been posted already, if it has it's probably been missed and brushed aside in the plethora of 680 threads.
