Bitfenix Shinobi XL Review
RJC
RJC
Don
29 May 2005
Kent
This is my review of the Shinobi XL case, I was luckily one of the three winners to get one of these cases.
I was hoping to finish the build this weekend but had a setback, the EK bay res arrived and it was the dual loop and not a single loop that I wanted :(
I will carry on with the review below and update as the new parts arrive and get installed.
Packaging:
The case arrives fine from Germany with the box getting a little battered on the way, with all the foam packing the case was unharmed.
The case:
Once the case was out of the box I was impressed, front and top are soft rubber material which is soft to touch, the buttons have a solid feel to them.
The side panels are very sturdy and do not flex very easily.
Rear cable mounts:
You get a box with array of cable ties, screws and cables mounts.
Under the top lid were my rad will be going, the front and roof are removable but you need to use a little force which I was worried that I would break in two!
Front of case, the main fan has a mesh to help catch the dust:
The array of cabe to the front ports, no Firewire port.
Hard drive caddy:
These are a little flimsy.
USB 3
Top fan removed:
My Build:
I will be using a triple radiator mounted in the roof, the radiator will only fit with the water connections at the optical drive bay end rather than the rear of the case as the water connections interferes with the I/O plate and rear fan, I don't think you would get away with angled connections on the radiator.
Reservoir, in my old case I used a tubular reservoir, which in this case being slightly smaller was hard to fit in easily without doing some mods, which I did not want to do. So I though I would have a go with a bay res, as this has turned up incorrect I am going to go a different route and use my EK DCP 4.0 which I used in a older build and get the attached reservoir which should fit in bottom fine.
Fitting a dual rad in the bottom or front is possible but you will probably need to use a slim radiator and possibly loose the hard drive rack.
Thoughts so far:
Plus points:
External case finish.
Solid side panels
Plenty of cables holes and mount points at the side to tie up cables
PSU can be fitted any way and sits on rubber mounts.
Fan filters for PSU and front fan.
Downside:
Rear fan only 120mm, holes for 140mm fan.
Front and top covers are hard to remove.
Hard drive mounts a little flimsy.
Not having a option to split the hard drive rack in two.
Parts arrives and the build goes on :)
Installed the new reservoir on the pump, decided to use my EK pump rather than the Swiftech.
Used new pipework and installed elbows on the rad: (did straighten the kink)
As you can see the hard drive cages have dropped a little, need a slight adjustment.
Graphics & BluRay drive installed and some wiring adjustments:
System now fully operational ans sitting in its home:
Hopefully a windowed side panel will be available which I can change from the solid panel.
Temps.
On my old 800d case I was getting around 49-56c on the CPU at full load with Prime and currently getting the same.
The GPU (GTX 580 at stock) I tested with Furmark and with the 800d I got 78c idle was 52c at with the this case I was getting 70*c, idle was 45c.
* Running Folding at home and getting 86c with fan at full throttle.
I definitely recommend this case to any one, plenty of room to work with inside and space behind the motherboard to hide spare cables and connections. The ability to watercool without to much issues.
The pro's & cons outlined above have not changed whilst continuing the build.
Fantastic :) Good news for me :) Didn't actually know that EK did a Dual Loop bay res. Hopefully they'll get that sorted out for you soon though!
kd
Thank you,
The reservoir that got delivered is this below:
http://www.ekwaterblocks.com/shop/r...n/ek-bay-spin-res-dual-loop-black-acetal.html
I'm going to try the res below with my EK pump rather than the Switech pump.
http://www.ekwaterblocks.com/shop/reservoirs-and-acc/res-pump-combo/ek-reservoir-combo-dcp-4-0.html
Nice review so far, look forward to the rest :)
That is one thing, which I would like to see improved on the Bitfenix cases kul1 that I mentioned in my review of the Raider! :p
To have about 5 cable mounts/loops spread out evenly inside the area surrounded by the red line.
Looking good so far RJC. Cant wait to see the finished article. Im wondering if ocuk will be stocking the internal usb extension cables? Id prefer the look of theese rather than the bulky looking way in which the usb 2.0 cables are attached to the usb 3.0 set. Should be getting my xl tomorrow.
Thanks Setter,
I don't think you be disappointed with this case :D
Hopefully you wil post some pics of your build :)
Sure will mate, even from only seeing it in pics and review videos, internally it's way better than my current lian li a70. Nice subtle exterior as well. Got a load of blue braided bitfenix cables as well to help with the look internally.
Im afraid youre going to have to check the top panel... Same with Linus at NCIX, he pulled the top panel first and broke the pins to hold it down... theres a reason why the front panel overlaps thetop... :eek:
Whoops :eek:
I can't check them until later tonight, but I just checked some other pics I took and the pins look ok, I can't remember if I took the front of first or not :p But I know I did not go to mad when removing them.
Whoops :eek:
Seems like a relatively easy mistake to make o.O
Didn't read the manual? :p
kd
What does the underside of the bottom 5.25" bay look like? is it completely hollowed out?
There any other locations for the HDD cages? Quite like the idea of running 2 x 360 rads in one of these as it natively supports one at the top and front.
kd
Manual, whats one of those :p
I did have a look at the manual.
I just downloaded the manual as I am not at home and it shows the first illustration of removing the top panel to install the optional fans then goes on how to remove the front panel.
There is a metal plate on the underside of the 5.25" bay, I need to check the gap between this and the front of the case (I can check tomorrow if thats any help)
Once the HDD cage is removed you might be able to use the floppy drive adapter to hold one hard disc or you will need to improvise.
@RJC: very nice first part of your review... the quality of the pictures are very good!
Linus at NCIX got a pre production sample of which the plastic connections of the top and front panels have been a little more "easy" than the current ones. In order so nothing breaks during transportation and when you remove them we make the plastic connections a little "harder".
