 - 6 Feb 2010
This I agree with.no, the point is you do need 2GB+ to run BF3 on Ultra
you ALSO need a better GPU than a single 560/570
Like the 6950 1GB vs 2GB above, while the 2GB is a bit higher in frame rate than the 1GB version, it also clearly shows that NEITHER are good enough to play at 4xMSAA. So realistically, both cards will need to have the MSAA reduced to 2xMSAA or none, which at that point there's probably not difference in frame rate between the two.
So basically, having a card of 6950 level and having only 1GB VRAM ain't really losing out to the 2GB version in terms of the game settings that both are needed to be at in order to provide playable frame rate. Having said that, there other factors to consider is that may be the 2GB version can be picked up for not much higher in price, or the possibility of going crossfire, which at that point there will be enough GPU grunt to take advantage of those extra VRAM.
In my honest opinion, 6950 2GB having higher frame rate than 6950 1GB on BF3 at 1920 res with 4xMSAA doesn't mean much, when they are both considered as fail at delivering playable frame rate (it's like making a big deal out of how one guy is doing better than the other guy in an exam, when both of them failed in the exam. If you give them a much easier exam to do, it is possible for the guy with the lower score to do just as well as the guy with the higher score. )
 You dont even know how Vram allocations work. Fact, 1.25 / 1.5 Gb are not possible on 256 bit memory interface
Thank god for that!
