Linux Install
15 Sep 2009
Manchester
I'm having an ongoing problem in trying to install any version of any Linux Distro that I have attempted. I download the ISO, check the MD5 to make sure it's not a flawed copy, and then use UNetbootin to burn the ISO on to one of my flash drives. Then I reboot and from the boot menu, choose to boot from the used Flash Drive. However, that's where the problems begin, using Linux Mint 12 as the example as it's the main Distro that I want to install, I get the blue screen where I can choose to test the memory, default, check the integrity of the disc etc, however when I move on from there I get the following message which it stops on every time:
Code:
3.351464] sd 8:0:0:0: [sdc] Attached SCSI removable disk
I have done some googling, but alas my skills appear to have failed me - the closest one I have found in regards to this issue is on the Linux Mint forums which has been unanswered. I was wondering if anybody on here had seen anything like this, or had any suggestions.
Computer Specs:
- i5 2500k @ stock.
- 16GB Corsair XMS3 DDR3 RAM @ 1600mhz.
- Asus P8Z68-V Motherboard.
- MSI GeForce 560Ti 1024GDDR5 GPU.
- OCZ 60GB Vertex 2 SSD.
- 250GB Western Digital 7200 HDD.
Things that I have tried:
- Ensuring that the ISO is perfect.
- Tried various ISOs including Ubuntu, Debian, Fedora and Linux Mint.
- Flashing the BIOS to the latest one and defaulting it.
- Three different Flash Drives, one of which had never been used.
I have run Linux before, however it wasn't on this motherboard, however I can't see the motherboard being an issue. I can run various distros in VirtualBox perfectly, however I am looking at a full-time Linux box and I don't want to have the hassle of having a Windows Install or having to virtualize everything.
Any help you can offer would be much appreciated.
Do you have anything odd plugged in, extra USB sticks, usb hard drive, e-sata drive... if so try removing everything and having another go.
Failing that, look for issues with the Vertex 2 SSD as the error message seems to be saying that it has found some 'storage' and then it halts, as if it can't read the storage. Now I can't see the sata 7200 drive being a problem, but the ssd could use some clever firmware which Linux doesn't recognise.
I'm just running barebones to try to figure this out. I have however just noticed that my Vertex 2 isn't showing up as detected in the BIOS, which is odd as I am running Windows on it, it's detected in the boot menu but not in the boot priority. I'm going to go with the assumption at the moment that this is a likely cause. I'm going to re-flash the BIOS now and see if it fixes the detect issue, if not I will unplug the SSD and try to boot in to a LiveCD scenario from the WD HDD.
Unfortunately nothing seems to have worked. I have tried with the SSD out of the system, I have made sure everything is up to date, BIOS etc, nothing is overclocked - it should work but no matter what it just won't work. Very frustrating.
Try installing from a CD?
Managed to get a DVD and a DVD drive, and unfortunately still the same error. I have tried everything that I can think of and nothing is working. So frustrating. I'm thinking more and more that it's some kind of hardware issue.
If the SSD seems to be the culprit then you can always try ACPI=off at the grub menu, just add it at the end of the kernel line. Mind you I think with the debian base distros this option is available from the menu.
ED - Note to self, read not skim :(
