The New Cases Gallery
Nah, that'd be telling lolol
can fit a normal loop in my H2 easily, Dual loops might be pushing it tbh
Having said that, I did spot a MM U2-UFO on that auction site the other day BIN for 140 quid :p
Thanks for the trust message about that other case, but as I said in it I am not actually looking for a case just now, just oggling yours :p
would love an orange and white caselabs sth10 though :D
Finally got some new 120mm blue led air penetrator fans, some other bits and pieces.
I'm chuffed to bits with this build :)
*Excuse the picture quality as my camera isn't that good*
Well...
I was going to do a build log / mod log as a fair bit has been altered with this build...
anyway, here goes!
Its not finished yet, cabling to do on one side under neath + I have a new window for the front coming shortly :)
Rather happy with how it turned out.
That's funky! Looks like ecto plasmic slime. Reminds me of those slime tubs you use to get late 80's early 90's.
Man, I want Matrix green goo!
GTX570 installed recently, The Asus 460 Top had a blue cooler so looked a bit out of place but this EVGA 570 fits right in :)
df1986 how much space is there under the plastic bit at the back of the case? (the thickness of it basically) also how much room is there inside? I'd love to watercool one :) I'd only get it if I could fit two rads in :p
mrk, I've always loved your pics :D and I love your pc, you should watercool it :p
It's an additional cost that wouldn't really benefit me really. I've thought about it before and I come to the same conclusion each time. I'm currently sitting here running normally at 36 degrees, that's with the H80 at lowest speed setting and case fans at 50%. It's about as quiet as an ambient room (or a laptop, to be fair) :p
