- 5 Feb 2012
That doesn't work on the SpeedTouch unfortunately.
I still want them to be able to connect, just not be able to access the router's configuration![]()
Is that a no thenPassword it.
How is everybody finding the 7800N now? I like it, but it can't hold a 6dB margin on my line.
TBH that's not where it shines. I now have 10's of days uptime - The DG834GT and VG2700 would not last a day.
Do you need a 6db margin given the BRAS profiles which have a very wide spread?
.Anyone know how to get DHCP reservation working on this router? On previous routers I have reserved certain addresses (via DHCP) just so devices get certain addresses and port forwarding is easy to setup. Also the devices stay on a DHCP setting so it is easy if they take them and connect them to other networks as most use DHCP. If I had static settings on my device I would have to change that when using other networks.
There is a Fixed host setting on the 7800n, but I have no idea what it is used for.
rp2000
Rp2000, yes fixed host is what you want. I use it on mine. Static DHCP is what I'd call it
Might have to try this one? Haven't the last 2 releases been pretty unstable?New Bipac 7800/N firmware 1.06g Release
