This is quality!
it looks like the bfbc2 vietnam chopper models & hit boxes have been put on the bf3 air vechials now.
This is quality!
This didn't work :/
I am on a 120hz monitor so my rate of 119.whatever is what I am after.
Not this tired ol one again guys.......lololol
+1....
To make Afterburner work with the mod you need to create a profile for BF3 in afterburner OSD. Then go to
C:\Program Files (x86)\MSI Afterburner\Bundle\OSDServer\Profiles
Edit the BF3.exe.cfg and replace the 'hooking' section with this:
Code:
[Hooking]
EnableHooking=1
EnableFloatingInjectionAddress=1
EnableDynamicOffsetDetection=1
HookLoadLibrary=0
HookDirectDraw=0
HookDirect3D8=1
HookDirect3D9=1
HookDXGI=1
HookOpenGL=1
Save exit etc and voilà!
Thanks to CK88.......Copy, Pasta and Spaghetti
so i gave up and uninstalled the injector.No... too long winded
Download
http://downloads.guru3d.com/MSI-Afterburner-2.2.0-Beta-15-download-2884.html
Make sure your osd is actually turned on via the monitoring settings
Load up the OSD, click the PLUS sign and direct it to the bf3 exe
Click the spanner top right hand corner and make sure the second box from the top is ticked ( enable compatibility with modified Direct3D runtime libraries ). Also make sure the OSD for BF3 is actually enabled don't need it globally!
That's it
I tell you what:
1. Report every one here who uses this "hack" on BL and see what happens
2. Install this add on http://getbblog.com/ and add everyone that uses this "hack" to your radar list so you can avoid us "pros"![]()
3. Or you can simply install it yourself so then you are on a "level playing field"
My k/d, score etc. is no different to what it was before I used this injector, the only difference is that the game is more enjoyable to play as it actually has some form of colour rather than a dull grey blue tainted look everywhere and thus my eyes no longer get strained as badly when I was on the game for a hour or 2.
It appears that you are the only person who thinks it is a hack, PB and DICE themselves have said they won't ban anyone for using it (and if any action does happen, it will just be a kick until it is removed).
Has any one made use of the shortcut packs, the only one I would go for is the co-op just for the simple reason I'm never likely to do those missions.
I would not go for any of the others as i like working my way up through the various kits myself.
See thats what the fan of performance enhancing drugs say in mixed martial arts too.
Dont support the small guy who does it all naturally and on his own. Force him to juice up and roid with the rest of them by legalising PEDS. its not the right attitude is it?
Define for me what a hack is. You'll find the fxaa injector fits the description quite nicely. You already know its a hack, your just enjoying it because you can, for now.
What did you mean by level the playing field?i thought this mod made no difference and just increase frames per second by using FXAA instead of MSAA.
When one person tells me one thing and then someone comes on and says something completely different that contradict the first, one of you might as well just admit it, yes it adds FXAA, and it also makes it easier to see things on the map, including opponents by utilisng optimisations to the colour palette..
As i said if its just FXAA your after, well you can all remove the hack and simply use the latest geforce drivers (if you have the nvidia card ) right..?
I just started using the FXAA Injector by danoc1 and I must say the enemy stand out a lot better now, loving it.
I have notice I've been getting a lot of lag with the game since the patch but my ping is between 15-30.
Yep, servers used to be buttery smooth, even with a 45-70 ping for me, but now even if I have 30 I get lag.
Can someone explain what the FXAA injector is? I'm thoroughly confused, although I have to say, using the colourblind settings makes reading things so much easier to read, despite me not being colourblind. I always modded the localisation of 2142 to give me orange/blue text instead of white, so I'm glad there's an option in BF3.
Seriously or are you just trolling?
Increased sharpness, increased gamma, increased saturation = way easier to spot the enemy in all situations.
anyone experience input lag/choppy FPS with MSAA enabled? im getting 60-90 fps with 6950 xfire but it feels like <30 fps and horrible delayed response to input, its like playing with vsync enabled
