£32 quid free when signing up for 32 Red casino... now whats so good about that I hear you ask...
Well, if you have time and patience and follow a system, you can pull out a profit without risk!
Basically sign up, play the instant casino and you get your 32 quid free. Now it has playthrough requirements of 30 x the 32... so 960 pounds worth of bets with a max of £8 at once... yet the game you will need to play only covers 50% of that, so you need to do it twice over.. so the 960 x 2 = 1920 pounds worth of bets.. sounds a lot but it goes quick enough.
Anyway the system to use to beat this is as follows:
Play multi wheel roulette - you get 8 tables (makes things easier)
The system is, spin them (auto) until you see a table (maybe more at the same time) get 5 of the same colour in a row.. ie 5 reds. Then what you do is put £4 on black... if it wins, good.. if it loses and its not the zero (ie green) you bet £4 again... if it wins, good... if it loses and is not the zero (ie green) go with £8 on black... do this until you win on that table.
Sounds complex and im pap at explaining things, but as long as you stick to it (dont put your own money in) and can handle variance then im sure you will come out with something... ive been as low as 20 quid and high as 120 when doing it, but coming out with 80 odd is money for nothing bar time on the PC.
**Note I would not suggest using this system with your own cash at any casino... this is just a way of trying to beat the odds (Fairly successfully) with some free no strings as such cash.
