erm... the K series processors come multiplier unlocked... meaning that Intel fully expect you to go overclocking them... they even offer additional warranty that will cover you even if it fails while OC'd
so having paid that extra money for what intel deem to be an overclocking processor, why is it suddenly "unfair" to make use of it and use that as a comparison
I'll explain again
It's not unfair if you want to compare an OC'd 3930K to an OC'd 3820 at the same OCing rate. So if you want to compare a 3930K OC'd at 4Ghz with a 3820 then you should comapre it to one running at 4.5Ghz as then you are comparing both of them with an equal 25% overclock.
Comparing a 25% OC'd 3930K at 4GHz with an 11% OC'd 3820 at 4GHz isn't unless you are only interested in difference between 6 cores and 4. If you're looking to compare them for overall power and performance though you should equalise the amount of OCing you are doing on both.
my motherboard was the cheapest X79 on sale and it also had all the features I wanted, so that saved me over £100 on buying a motherboard that does support BCLK that would allow the 3820 to stretch it's legs
Firstly, saving £200 and spending £100 more still leaves you £100 better off so I don't get the argument really.
Secondly, what do mean your mobo doesn't "support" bclk overclocking?
so in my case your rather wonky to begin with logic goes straight out the window, as the 3820 wouldn't overclock at all, where as my 3930K goes to 4.5ghz easily with just a multiplier change and a small voltage tweak
Yes I'm the one with wonky logic despite the fact you've just admitted you could have spent £100 less on a decent mobo and just got a 3820...how does that work.
And stop it with the cr*p about a 3820 not being able to OC "at all" on your mobo. I don't believe there are any X79 boards that are that ****...even the cheapest board is still made to "enthusiast" standards.
considering I also got a good price on the 3930k, I actually paid the same if not less than you for my system and yet you are trying to tell me that mine is not good value and isn't a goodly % faster than yours...
For the 8000th time, I am not trying to tell you personally anything, I am asking for MOST PEOPLE (who are looking at X79) is the extra £200 worth it. There have been some sensible answers so far about the when you need it and when you don't which are all valid, stop taking the question as an attack on your personal choice to buy one...jeez!
every comparison I've seen of overclocking the 2 show that they oc to within 1-200mhz of each other on the same system/cooler... 200mhz is pretty negligible at 4.5-4.8ghz so then it does come back to 50% extra core...
am I making full use of all 6 cores currently? maybe not, but considering I went X79 purely on the basis of extra PCIe 3.0 lanes with a view to SLI performance, and given that 2500k users do seem to be hitting CPU bottlenecks with a pair of GTX680's, it may not be all that long before my 3930k shows it's true face
Being X79 (and thus also PCI-E 3) the 3820 would also provide you that (staying on topic).
you also keep saying £200 as if it's a hard and fast number, but depending on where you go looking the price differential between a 3820 and 3930k can be as little as £140... knock £100 off for not needing an uber overclocking board to be able to do BCLK clocking and all of a sudden you're in the realms of £50 price difference between a 3820 system @ 4.8Ghz and a 3930K system @ 4.5Ghz... I know which I'd rather have
I think your making way too much out of your mobo argument my friend. I have the Saberooth, not the Rampage Extreme and I'm fine OCing. Don't implying that you need a ROG level mobo to be able to OC a 3820.
or you can just go ahead and keep sticking on more and more provisos to limit the scope of your comparison so that it makes it basically meaningless
If you buy the hardware from supplier X and you MUST buy this motherboard and THIS cooler and you only run these 3 apps and the maximum OC you can do is Z%, THEN the 3820 is better value "in my opinion"
Ha ha, I'm doing the exact opposit of shifting the goal posts, I'm doing the scientific thing and creating constants for fair comparisons.
It is others who want to compare a 12% OC'd 3930K with a non-OC'd 3820 or compare the price of 3820 on OCUK with a 3930K they've seen being sold on eBay to prove the price difference isn't £200.
