I would go for the hankook V12, £40 cheaper per set for the same performance.
Depends how you define performance, the PE2 have a stiffer wall and last longer
[TW]Fox;21684564 said:Do you mean the performance is the same, or do you mean that you personally didn't notice an immediate difference when you went from the worn PE2's fitted on your car when you bought it to the much cheaper V12's you chose to replace them?
As thats rather two different things.
I've not personally tried the V12, but know friends that have had both,
and also going by reviews/tests i've seen comparing the two.
[TW]Fox;21684639 said:That doesn't seem strong enough to be able to categorically state the two tyres have identical performance properties?
They came out identically? Could you link to these?
They actually came out better in testing than the PE2 in dry/wet grip and braking. I could probably link to them if i could be bothered, but alas, i can't.
[TW]Fox;21684663 said:Don't make a statement if you 'cannot be bothered' to support it then![]()
Sooooooooooo PE2 will feel nice and sharp upfront? Car feels **** the now as the tracking is out since I said Hi to a kerb.
I was very happy with the PE2, even on track it wasn't terrible, especially for a road tyre. The V12 isn't cheaper because its worse, its cheaper because its not made by a company as big as Michelin.
It's only a tenner in it for me though so not that much of a saving.
[TW]Fox;21684731 said:I've found the tyre test, was it the Evo one?
The V12 appears to come 2nd from bottom. The PE2 is 5th.
I make it £230 for the V12 fitted and £260 for the PE2 fitted?
I'll only be doing the fronts as the rears are nearly new T1Rs from February.
So £120ish vs £128ish for the Michelin.
Makes sense to go for the PE2 for the sake of £8 then. Do they make CS3 in 195/50?
Nope,they start at 16" so maybe when I get some Rota Grid drifts in 16x8 I can get the PS3.
