Permabanned
- 9 Aug 2008
Have you got any pictures of the back of your pfsense build groen? Do you have a vdsl2 card in the build?
vdsl2 card ?
No, it goes from the modem in to a gigabit nic. It has been working great since it finally got an ip address.
I have tried disabling all services on pfsense, like snort, ntop etc. I tried disabling pf and all services on the remote box, but randommly the ssh session just fails. Everything else appears to be functioning correclty, sftp downloads full speed, games are fine.
[TW]Fox;21721729 said:That looks like the sort of speeds I am expecting - what did the BT checker predict for you?
Try and keep the servers the same mate for testing. I wasn't home last night to try a test myself but I will be tonight, so for what it's worth if you want to compare a few it's no problem.
Mine this morning:
Cant say ive ever seen manchester server come up for me. Normally Scotland or down south in London. Must do another check tonight seeing its the 10th day and things should be "normal".
Mine always (well apart from London once when all my tests were rubbish) starts from Aberdeen and I select either Manchester or Coventry
I never knew you had the option to "select". Does this just a difference on the test itself or for your overall connection?
Also, are you using the HH3 or have you gone for a different brand. How does one rate the HH3. I wouldnt mind an extra GB port!
Speeds and Pings seem to vary throughout the day. Early hours of the morning everything is full speed. Think there's a few bandwidth issues in certain areas with the new upgrade.
Like I said DirtyJester I think it's just certain areas.
I got suspended for posting the cool jesus image.
Snip
