thermal paste nightmare
12 Dec 2005
I was installing an i3 today for my new pc.
I didn't realise I had a smear of thermal paste on one of my fingers. As I picked the CPU up I smeared thermal paste on the back of it. I softly wiped it off but when I held it to Tue light I could see discoloration where the paste was.
I'm scared to try it, will it be OK?
The CPU really has been through the wars. As I took it out the packaging it dropped on the floor luckily carpet.
All seems well though what sort of thing should I keep an eye out for?
It exploding.
If it works it works. CPU's generally work, or not.
That's really good to hear. I get paranoid about stuff like this though.
lol, I hope you dont any warranty claims later on.
Me to. I think everything is fine though, I'm worrying that something I've done might affect the performance of the CPU or would that be impossible?
Cheers
Guys this is what the product description of the thermal paste says
Description
Cooler Master HTK-002 thermally conductive compounds are grease-like silicone materials, heavily filled with heat conductive metal oxides. This combination promotes high thermal conductivity, low bleed and high-temperature stability. These compounds resist changes in consistency at temperatures up to 177C (350F), maintaining a positive heat sink seal to improve heat transfer from the electronic device to the heat sink or chassis, thereby, increasing the overall efficiency of the device.
I was using some 'Diamond' thermal compound and thanks to the design of my Dell's BTX HSF.. jsut trying to get the cooler off ripped the CPU out of the socket!
So even with the thermal not being wiped off with alcohol (Just gently rubbed it using tissue, could still see a dark streak where the thermal had been)
Everything should be OK? As said it's working pretty fine right now...
Cheers
Oh well it's working I guess that's all that matters. The thermal paste thing does worry me a bit though but it seems the type I used doesn't conduct electricity.
Just hope everything will be OK in the long run. :)
Is their any risk of the pin side getting burned? As said I made sure all the thermal was wiped off it but when I help the CPU up to the light I could still see streaks of where it had been.
Cheers
