Barca didn't need a plan B, they didn't play their plan A, they simply needed to play their plan A and they've have thrashed them.
Go look at the 5-0 Barca vs Real game, and most of Barca's best performances, you have teams defending for their lives in the same way as Chelsea with one key difference. Against Barca basically all the goals came from passes both diagonally inbetween the defenders, or over the top but always to either, Messi, Villa, Pedro who would run along the back line then turn and run in behind, the second they turn the pass from Xavi would ping in brilliantly and bang, goal. Running at the defence, tonight, in the first leg and against Real, Messi stood 10-20 yards from the CB's and made almost no runs at them all night, his work is happening 30 yards back from 99% of his best play in the past 4 years. Sanchez spent most of his time standing next to a CB, utterly static, and giving Xavi nowhere to pass the ball to. The utter lack of movement meant CHelsea had a ridiculously easier time than they should have, to cover runs, cover movement and not have to fill gaps as players move to track runners.
Barca didn't come close, anywhere near their plan A, plan A would have worked, they've forgotten how to play it.
